- Jun 4, 2020
- Age
- 40
- Seattle
- Seafarer
Are you going to continue with the potential buying process or look elsewhere?it went reasonably well. we found the beginning of the exhaust corrosion in both mid sections; its not un expected and at 185 hours its not too bad yet but its not going to go away. Sea trial went very well, the boat rode great, there was a little chop, maybe 2 feet and probably 20 knots of wind and she rode very well. the surveyor noted several items needing attention which isn't surprising on a 16 year old boat that hasn't gotten used much.
did you access the holding tank from the mid berth side or did you have to remove the cover for the fuel tank and go at the holding tank from the aft side? Good news that the macerator was outside the tank, i was thinking it was inside the tank based on something i read somewhere.I replaced the macerator pump on my 2008 Sailfish earlier this year. The macerator sits on top of the holding tank. It's a bit of a reach to get the mounting screws and hoses, but doable. Luckily I have long arms. The pump is readily availble at boat stores. I also had to replace the hand pump on the toilet, which is very easy to do. Now all plumbing works fine. I just need to empty the holding tank before I have the boat pulled for the season.
Hopefully you do not have to do anythimg with the holding tank. That looks like a bigger and harder job.
2004 SF has the Groco Macerator. The unit is bolted to the top of the tank but the mechanical structure of the macerator is in the tank. It is s pain to get to but as used2sail said it is doable.did you access the holding tank from the mid berth side or did you have to remove the cover for the fuel tank and go at the holding tank from the aft side? Good news that the macerator was outside the tank, i was thinking it was inside the tank based on something i read somewhere.
Thanks for the pictures they are very helpful. I reviewed some pictures I had taken of the boat I'm looking at and I saw the hatch in the mid berth aft bulkhead. I had only seen the side of the tank from the hatch below the center of the mid berth where the sea cocks for the head are and the hydraulic pump for the trim tabs is mounted. It looks a lot easier from the pictures you sent than what i had initially imagined.I accessed the macerator through the mid berth hatch. You only need to remove the two mounting screws on the bow side of the mounting bracket. the stern slide slips under the screws that hold the other "thing" that is on top of the holding tank. Attached are a couple of pics to show you what I mean. When you buy the new macerator, you'll also see the back two slots that slide in, versus the front two mounting holes.
I have a 2000 sailfish 272 and am out of NH/southern ME. If you’re interested I have a great Yamaha mechanic that’s mobile and can survey the engines for you. My previous boat had a 2002 F225, he did the engine survey when I bought and sold and I had him scope and do the exhaust kit before I sold in case I kept it. Also, the sales guy is wrong when it comes to the hours and corrosion issue. The issue has nothing to do with hours, first gen Yamaha 225’s used dissimilar metals in the dry section of the exhaust so it can happen just over time with moisture in the air or water that has enough salinity or debris to conduct it. As for the boat, I tuna fish primarily and can typically only fish sundays given the current RFD’s so I go down every Saturday and spend from Saturday-Sunday night on it. Me and my fiancée also vacation on it and sleep on it a handful of times a year together the most we’ve done is 5 days 4 nights. I’m on the shorter side 5’10ish and the cabin is tight lengthwise when laying on one side of the vberth. When I’m alone I sleep in the middle with no issues with head room. Ours has all of the amentities (ac/hot water heater etc), but we are on a mooring and I don’t currently have a portable generator so can’t use them unless we rent a slip. I’m never too hot on it and I typically run warm especially at night but the temp drops enough on the water that it’s comfortable to sleep. The vberth can become a little stiff on the back after 2/3 nights on it but a foam mattress pad between the sleeping bags and cushions makes it way better. Mine doesn’t have a carpet below and when I sleep on it I’m fishing for stripers with live/chunk mackeral off my mooring so before bed or heading into the cabin to grab something I wash and/or sanitize my hands, change clothes and leave the fishing clothes up top. One thing that the previous owner did to make the cabin way more comfortable was make a screen for the hatch. So I can keep it open for airflow and not get eaten alive. I’ve put ~400 engine hours and spend 10-20 nights a year on the boat the past 2 seasons in the area you’re looking at so if you have any questions or want more details PM me and we can talk further. Curious what marina is selling as very few to no marinas in NH on the ocean are certified Yamaha dealers with factory certified mechanics from what I’ve found the past 3.5 years owning Yamahas.I’m kind of stuck using the marina where the boat is being sold, there’s no trailer and even if there was my 1/2 ton truck wouldn’t get very far with this boat. I asked the sales guy and he basically told me not to worry that with such low hours there wouldn’t be a problem. I’ve already contacted a surveyor and asked that the engines get looked at, hopefully he has a guy who is willing to do the inspection at the marina. I’ll discuss the corrosion issue with the salesman and surveyor on Monday.
Where we live in West Palm Beach, we have several marine bedding options nearby. We took the Grady mattresses to them (E.J. Schraeder) so they could make an exact fit with 4" pillow tops. Now we just go with the pillow tops. Makes it easier to get to the storage areas below the cushions as opposed to having two sets of cushions in place. And, when we want to raise the table into place, there is only one cushion to set aside.Rob, Im hoping we find the cabin as liveable as you do. We'd really like to weekend regularly, and hopefully get into the longer trips similar to your great lakes voyage. I like the notion of occasionally staying in a hotel for a chance to reset for a night or two, thats a great way to handle a longer trip. Where did you get the mattress toppers made, I've heard several reports of the factory cushions on the vee berth being uncomfortable so we should get something better in place before we try to overnight on the boat.
Run them often, keep up with the maintenance, sitting idle is like cancer imo. They are happiest catching fish. Make sure you know where your gas is coming from and if it's a quality place, some marinas are sketchy, water in there is no bueno. I do run seafoam or the like through them once per season. Otherwise they seem to get a little congested during the hottest months at low RPM, once that's done though they purr just fine. My exhaust stacks were done by my local dealer before I bought the boat, they have been fine and no issues beyond the standard stuff everyone will have. People knock the F225's but they are a great match for this hull, they have given me next to no issues besides my own self-inflicted encounter with a submerged object, and are relatively easy to work on.Thanks for the information on the fan to ventilate the cabin and the heads up on the cushions. Its nice to hear you've gotten the number of hours on your 225 Yamaha's , any secret to your longevity??
I think i've hammered out the deal on the boat, pending sea trial and a survey we are moving forward !!
