Bilge pump questions
That sounds perfect! Nice job! Now, stop looking for trouble!
When you get antsy, wax something:)
Reactions: RussGW270
RussGW270
lol! Sir, yes sir!
I am going out there, zip-tying the damn cables, and closing her up and loading things up. If a wasp flies out.. I will ignore it and keep on keepin on.. lol
Look for some live youtube videos...I will make a link on a post when we do it tomorrow, from the coast.. Wake saturday, sunday, monday, tuesday....lol
R
Meanwhile
Warren, OR
Russ, you have inspired me to hunt down my problem. My forward bilge works from the helmet switch, will not work from the auto switch.
Meanwhile
Warren, OR
I gave up. The boat is wired for a non-automatic bilge (2 wire) , so I ordered a larger non-automatic bilge pump. It should work from the helmet switch and the float switch. 2 wires from the bilge pump, 2 wires from the float switch, both sets disappear into the port side. I don't feel like rewiring so I'll go with the flow.
By 'wired for a non automatic bilge pump', what are you referring to? If a bilge pump works automatically and manually, it has to have 2 12v feeds, one from the battery compartment (auto) and one from the helm(breaker or fuse off the accessory buss)
Are you missing a wire?
Bilge pumps without some sort of water level detection builtin will be two wire. Pumps for manual or auto with an external float switch will also have 2 wires from the pump. Some bilge pumps with a built in manual or electronic water level detection will have 3 wires.
Meanwhile
Warren, OR
2 wires from the bilge pump, 2 wires from the float switch, both sets disappear into the port side. An auto pump has 3 wires. Without rewiring, an auto pump will not work. I'm not digging into the port wire loom. Just easier to order a 2 wire pump.
