suzukidave
- Sep 24, 2013
SilverLining said:Thanks to all for the suggestions and comments. After my experience last month, my boat will not go back off-shore until an additional bilge pump is installed in the aft bilge of my 272. Although it might be belt and suspenders, I am also going to add a separate high water alarm in the boat as well as having an alarm/light in the new pump system.
My thoughts are to add a 2000 gph pump with the float switch only several inches higher that the float switch for the original pump which is now a 2000 gph Rule. At some time in the future, I will add another battery under the live well as suggested by fishbust. This battery will be dedicated to the new pump but will be able to be used as a "utility or spare battery" in addition to the three already in the boat.
For whatever reason, G-W wired the forward pump(1500 gph) to the house battery and the aft pump(now 2000 gph) to the S/B motor start battery, so I will probably wire the pump to the Port starting battery. ?????
Checking the photos supplied by fishbust and RobertH seem to indicate that the new pump is mounted higher that the original pump. Help me understand the logic for this. Seems that in an Oh My Gosh situation, when the lower pump/float switch fails, you would want to pump out as much water as you could(while you attempt to effect repairs). In that case, I would think that the pump should be mounted at about the same height as the existing pump, not 4 or 5 inches above it. I am aware that the pump will shut off whenever the float switch tells it to do so now matter where it is located. What am I missing here??? Or am I just overthinking this? :hmm
your boat won't sink with 4-5 inches in the bilge.
you only want one pump to trigger most of the time to save your battery. especially sitting on a mooring in a steady rainstorm.
the other advantage is that your back up float switch is not going to see a lot of dirty bilge water. my only failed float switch was caused by grease and dirt build up in the float switch hinge from dirty bilgewater. now i clean my bilge every year.
