Binnacle tilt/trim thumb swich
Rfazilat
Hello all
Recently replaced the switch. However, the original switch had some sort of semi perm putty it was seated with into the housing. I was able to push the switch out and replace it, but dont have an idea of what putty was used and will need reseat the new switch. any putty advise?
Good question for sim Yamaha.
Are you sure it was original? Is the new switch wobbly? Putty sounds like a makeshift cure for someone breaking some plastic off the seat where it should sit firmly.
Parthery
Atlanta, GA
I changed out the switch, and ultimately the handle, on a 704. No putty. Someone tried to make a temporary fix.
