I would rather find the source of the low voltage than install an UPS.
As long as this reboot didn't always occur, something has deteriorated and/or changed and I would loose sleep not knowing what it is since it may get worse.
I agree with Skunkboat about the batteries also but voltage tests should prove if that is the cause.
So I tried to take mine apart this morning to figure out if I should get the 5/16 or 1/4 version but could unscrew the the terminals to figure out...
Any recommendations on what I can use to loosen the screw? I cut out all of the solvent that was used to cover the terminal but still no luck.
Also, any idea if this version is 1/4 or 5/16? At this point it looks like I should just replace those cables as well.
Two ways that may work. Grab the screw head sideways with a vice grip with sharp teeth on the jaws. That usually works.
If not ,grind the screw heads off with a dremel type tool and abrasive wheel. A grinder with an abrasive wheel may work also if you can get it in there
