- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
doug228 you're right, it can be run on 455khz. It gives a crisper image. I don't know what I was thinking. Maybe my old Echo94 with CV51 didn't do that.
I was out yesterday and looked for a wreck I had numbers for but have never been on. Without the sidevu it would have taken a lot longer to find it and to mark out the edges.
I took screen shots but I left the sd card in the unit.....get them next time and I'll post
Not sure what problem Hookup is having. For things with straight edges it works great at showing an image. You have to be moving in a straight line for the image to look like something. And it looks more like a picture when the object is to one side. If you are over the object you are better of looking at downvu.
When I've used it on bottom formations like Shrewsbury Rocks, its not as "picturelike" unless there is a straight ledge. Probably because my brain doesn't understand what its seeing. But it still shows that there is a high spot to the left or right, and thats what you use it for.
When I look at Hookups image it looks like its working correctly. I flipped the picture to make it easier to understand.
I see a square-ish object in a depression(white arrow) on the starboard side, 40 ft from the surface(on an angle). The bottom is 13 ft straight under the boat(red arrow). I see a bright edge (yellow arrow) that shows that the object is sticking up. I see a shadow (green arrow)of the object.
I don't think its the wreck Hookup is looking for. It seems way too small given the scale of the image. I would guess its a mooring anchor block....but of course...its all in my mind what I see.
