- May 30, 2023
- Age
- 64
- Seafarer
Update:
Replaced all the old wood, refiberglassed the panels and feels solid as a rock. Was definitely a two person job and could’ve used another hand putting it back together. I cut all fiberglass to size and layed everything out before and then worked as quickly as possible to get everything together before the epoxy set even with the slow cure west system. Entire process took about 2 hours. Placed wax paper on the fiberglass with weights to weight them down. Wax paper came off perfectly and trimmed/sanded extra fiberglass to fit.
Only hiccup was when I went to put the panel back into the boat I relaized the fuel sender seal is pretty shot. Bought a new KUS 15" unit but left the tank full over the winter and need to siphon some fuel out before replacing the sender and this panel. Should be done this weekend but panel felt great when I walked on it.
