I have a 1995 268 Islander which is long over due for cockpit deck drain hose replacements . Unfortunately there is no way (that I can figure) to access the starboard side without cutting an access plate into the deck. In fact the port side may be easier to do if I cut into the deck as well. I was wondering if anyone had photos, recommendations, lessons learned for this project. I am guessing the configuration would be quite similar on the Sailfish and Bimini as well as a few other models.
Also the bottom of my deck drain thru hulls are under water so I was planning on going with bronze rather than stainless. Any one have recommendation on how to properly bond these.
-Dan
-Dan
