Dome light switch fix help
mleads310
Brooklyn NY
Does anyone know how to remove the dome light to access and replace the spreader light switch? I’ve removed the cover and the 2 small nuts. The light is still solid as a rock and I don’t know what’s holding it on.
If you ever replace that dome. I would like to buy it from you!!!
offshore
How did you get the dome light off after you remove thr 2 screws holding it up?.Thanks
Jzeno186
NY
I had to pry it off with a flat compound knife… it was adhered pretty good. But it prayed off no problem !
