freddy063 said:
when you store it do you spray fogging oil in your carbs?
I don't have carbs but I do fog my cylinders. For either, add stabilizer to the gas and run the motor to get it into all the bowls, filters etc. Then you can fog the carbs by following the instructions on the fogging can.
Many folks at my club do not run the carbs dry since that can cause gaskets to dry out, shrink and eventually leak. That is especially true for some older motors. Running dry also causes the motor to run lean towards the end of the running and that can be an issue. So my advice is follow the instructions on the can
