Error in converted waypoint files. Possible?
I forgot you said you had a Lighthouse II system e127 that unit supports .GPX format. Looks like you can just put the .GPX file on a SD card and load it.
With the Homescreen displayed:
1. Ensure you have the memory card containing the gpx file(s) inserted into a card reader slot.
2. From the Homescreen select My Data > Import/Export > Retrieve Data. The file browser is opened.
3. Browse to and select the file you want to import. A confirmation dialog is displayed.
4. Select OK.
Let me know how you make out.
Hookup1, Thanks a million for helping me with this. I've got to admit it was a little scary deleting all those waypoint Xs while not having confidence that I had got the new info properly loaded onto a new card. Thankfully it all worked out and I now have names in the list so I can pick out a fishing hole and draw a line to it. Can't thank you enough.
John
You're welcome. Good luck and catch them up!
P.S. I thought about backing up first but didn't want to confuse you. Deleting was safe - you had what Raymarine sent you.
