- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
"Generally" speaking, the industry as a whole (at least from my 35 years in the industry) will use the terms "in/down" and "out/up". I realize that "down" isn't technically correct over the entire range of trim because after the engine is trimmed down to vertical it then starts to go up again. But we don't worry about that technicality - it's just a general term. In fact, many trim buttons (including something like a stand-along rocker switch) will actually have one of those two sets of terms used. Forward and backward, while logically correct, aren't really used.Down and foward are the same thing, up and back are the same thing. Down/up are a little confusing because your engine starts up high before you put it water and put the engine down. But you go in the down direction enough and most, if not all, outboards will go past the 90 degree straight up and down and tilt the plate forward a bit. So it acts like a trim tab.
Referring back to what I said above about the anti-vent plate... it only slightly works like a trim tab... and really only until the boat gets on plane. The primary force of either lifting the stern or pushing it down comes from prop thrust.
