The amount of $ you will recoup if you sell the boat is usually squat.  If the HPDI's are having an issue with the gas, a 4 stroke will too.  Use good filters and check for water often if you don't have a plastic bowl.
I'm suprised you're getting the same GPM with your HPDI's as F225's are. Normally the 4 strokes clean the clocks of 2 strokes when trolling.
