- Feb 27, 2023
- Age
- 46
- Islander
Is there a fuel shut off valve/where is the fuel shut off valve in a 1996 Grady-White Islander 268?
Unless Michigan law has a certain place it should be (or not be), I would put it where ever it makes the most sense for you - both in terms of using it and in regards to installing it.Thank you for the response. No issue. I have to have an accessible fuel shut off valve to be in compliance with state of michigan charter boat laws. Any thoughts of where best to add? I am considering next to seperators
Good point.I'd be surprised you don't have valves if you have two tanks.
Twins but only 1 tankYou have twins right? One or two tanks? I'd be surprised you don't have valves if you have two tanks.
My 1997 268 Islander has fuel valves. Twin F150's and main and aux tanks. They are located aft port side compartment. Lift the bucket out and they are there. Alternative is look in battery box and follow the fuel lines from the filter cans.Is there a fuel shut off valve/where is the fuel shut off valve in a 1996 Grady-White Islander 268?
