- Oct 16, 2007
- Age
- 72
- Cape May, NJ
- Islander
Recoil Rob could probably do nothing with the charts, add the second unit and everything will work fine. Although I would recommend the software upgrade to v30.10.Thanks for straightening me out.
You're correct, I bought the Vision upgrade for the first unit.
Interested to hear what you find out.
I've never used Active Captain, perhaps I'll set up the older unit on a battery to update.
What irks me is paying $250 for the card and after a little more than a year it's, while not useless, superseded.
After updating the BlueChart/G3 on the older unit, can the same Navionics in the new unit be installed on the older one if the Vision card is removed?
The Garmin 86xx series and to a lesser extent the 943/1243 series are older units. But they are multifunction displays and not much is changing. I expect big changes in the sonar technology in the coming years. But charting is charting - the performance is good at this point. Maybe resolution upgrade to 4k displays at some point.
