ROBERTH
Agree on the confusion to why Grady used small squares as that can't be as strong as a solid sheet.
I think once the balsa is wetted out and layered, it will not allow movement and will be very strong.
I am adding a 4th battery, so maybe I should strongly consider reducing the weight. The plywood is 49# for a sheet. I would not use the entire sheet, but guessing I would come near the 40# mark with what I would use.
I can't find the weight of the balsa, but when holding the entire stack of pieces I have that is enough to do the smaller hatch, I am guessing it would weigh 5#'s.
So, back to the weight savings, I might end up saving about 30#'s if I went with the Balsa, and add the weight of the wet wood, might gain more.
I will weigh the panels before and after to see what I end up with, whichever way I go. Now, leaning on the Pro Balsa.
