I agree with what Seasick mentioned, especially the dispersal or moving around of weight, as well as I'm not sure about Florida but in the Seattle area we have gasoline that has ethanol in it. If that's the case in Florida, I might leave a few gallons of fuel in the auxiliary tank as well as add some sort of fuel stabilizer as water/moisture tends to not like fuel very much. Also, replacing your fuel filters/water separators and pouring out what water might be in there will definitely help keep your gasoline fresher a bit longer. If your smaller tank truly is 73 gallons and a gallon of gasoline is 6.3lbs/gallon then that's 460lbs of added/lost weight right there, and as Seasick mentioned... that could definitely throw off the ride quality or stability of your boat. Might be worth a phone call to Grady White to see if they have any recommendations?
