I just bought a 1995 Sailfish 272. It's in pretty good shape. I've replaced all the pumps, fuel lines, upholstery, and some of the elctronics.
Now I'm on to the gelcoat finish. The hull has a little shine to it. I removed all the old registration and some striping. The areas underneath are the shiniest on her. They are a little yellowed. Is that the original color of the coat?
I've tried several things on the yellowed areas including sanding, polishing, and 3M restorer. Will I get the color the same? It seems when you sand it, the area around the old letters takes on a similar color to the yellowed areas. The hull has a more dull look after everything I try. Does that go away with the waxing? Should it shine after polishing? The top side is pretty oxidized. I've never done any gelcoat restoration. I'm paranoid about damaging the coat.
