great job on the seafarer!  we have an 87 22 seafarer which has questionable transom and the boat will need engine upgrade.  question-what about the weight of the 2 115's, how do they perform-speed, fuel use, handling.  im just handy enough to be dangerous but have a professional who does side work and the boat in in our barn so i will be doing the slog work and he the glass (i hope).  our choice-as i see it, is to do what you did or add a bracket and a 200-250.  first check shows the two eng set up you have would run about the same cost-weight is my question!  boat is used st marks, fl which requires long runs to get to any water over 20 ft deep and the bay has an almost constant chop.
