- Jun 6, 2024
- Age
- 33
- Offshore
I just took the metal transom bracket off of my 2007 Grady White 330 express to replace it with the vinyl cap and glass it over but discovered the attached pics and the fiberglass guy got moisture readings in the engine bracket holes. Any reccomendations on how to fix- will I be ok to replace just the top area or should I do a full transom replacement- and if so cost wise what do you think it will be around? Thanks!
