GREAT GRADY FAQ
JEMJR
i have just bought a 1988 24 ft offshore it has one of the fuel tanks missing . it has the one in the front that takes up all the space in that compartment . the back compartment has a open space, and in the back of that space is the water tank . just wondering the fuel tank size of the one in the front, and do i need the one in the back . and does anyone know the size of the one in the back . thanks for the help
Tango21
1. What year did Grady White start building the SV2 Hull?
The SeaV2 hull design was implemented on Grady-White boats in the following sizes and years:
28 ft............1989
26 ft............1991
22-25 ft.......1992
208-209......1993
192.............1994
180.............1998
2. What is the Sea V2 hull?
A Continuously Variable Vee Means Soft and Stable
A SeaV2 hull design has no two places on the keel where the deadrise is the same. The vee continuously sharpens from the transom to the bow stem. A SeaV2 hull design with 20 degrees of deadrise at the transom will have around 30 degrees amidships--more than even the most radical older deep vee designs. The deeper vee forward means a softer ride at sea. Less vee at the transom coupled with wide chines provide stability at rest and when trolling.
3. Where can I get an owner's manaul for my Grady?
http://www.gradywhite.com/customer/manu ... ected=2004
4. Where can I get a Grady White catalog?
http://www.gradywhite.com/customer/catalogs/
5. How can I add my photo to the Great Grady gallery?
Email your photos to admin@greatgrady.com. Make sure to include your forum username, boat year, full model name, and any comments you would like to make about the photos.
6. What company makes the Grady White anchor rollers?
http://www.windline.com
7. Where can I view some Grady White Factory Pics?
http://www.greatgrady.com/forum/viewtopic.php?t=280
8. Where can I purchase canvas curtains for my Grady?
http://www.greatlakesboattop.com/
9. Where can I purchase seats and cushions for my Grady?
http://www.wiseseats.com
10. Where can I buy custom cabinets to replace the fridge?
http://finaddictmarine.com/_wsn/page7.html
11. Where can I get discount Yamaha OEM parts?
http://www.yamahaoutboardparts.com
12. Who makes the hardtops for Grady-White?
http://www.wmwworks.com/f-marine.html
13. Where can I purchase an Owners Manual or a Service Manual for my Yamaha Outboard motor?
http://www.yamahapubs.com/html/year.jsp?type=OB
14. My windows are leaking. Where can I purchase the vinyl plastic molding that covers the screws in the window frame?
http://www.waterbonnet.com
Send sample to the TN plant - or just call - they will know what you need based on the year of your Grady
15. How do I work my trim tabs?
http://www.greatgrady.com/forum/viewtopic.php?t=3580
16. How do I refurbish my cockpit bolsters?
http://www.greatgrady.com/forum/viewtopic.php?t=2834
Reply to #8 - A&J Canvas, Vanceboro, NC, makes most of the OEM canvas for Grady White Boats in Greenville, NC. Provide them your Make/Model/Year and Hull ID number and they likely have the measurements to refabricate your canvas. Phone (252) 244-1509
Cesarmartinez123
Hello, I have the following question, really hope you can help me out.
Does anybody know where is located the secondary (hidden ) VIN number in a 1989 Offshore Walk Around 24 Ft Grady with the motor sited in a original bracket ??
Thank you in advance!!
Johnny Dollar
I have a 1996 Seafarer and I would like to install a newswitch panel. Here is my question...are the switches pretty generic on the backside of the panel. I have looked online and would like to order a new panel with new switches. Any cautions I should be aware of
i have a 91 228 and i will be doing the same. most of the switches perform 2 different functions on my boat,
i have found some generic switch panels that do fit but i am also having to buy switches that perform the different functions they are around 10 bucks a p[iece and the single function switch it around about half price
only info i have from my searches is the on-off-on switches you must by separately and add to the panel
Johnny Dollar
i have a 91 228 and i will be doing the same. most of the switches perform 2 different functions on my boat,i have found some generic switch panels that do fit but i am also having to buy switches that perform the different functions they are around 10 bucks a p[iece and the single function switch it around about half priceonly info i have from my searches is the on-off-on switches you must by separately and add to the panel
