ceadmilefailte said:
			Gents thanks for all the posts! Here is what I've done so far: checked the fuel supply in main tank and alt tank, good to go. A also removed both fuel fill caps to relieve any vacuum? Then I ran on alt tank both ran fine. Switched both engines to Main, 5-7 minutes both conked out first port then starboard. I'm still thinking it's in the transfer switch?
Your first post said you were running on Main and switched to aux and motors died. This post you were running on aux and switched to main and motors died.
This suggests that it is not a tank problem since it
 can be made to run correctly in either position, only giving a problem shortly after switching tanks.
You have two fuel switches, one for each motor to choose Main or Aux...correct?
both switches bad, in both positions....not likely...but possible?
I suspect that you are losing the prime when switching. Primer bulbs being the number one culprit. Yes, they could both be bad. (brand new ones can be bad...they suck)
Also, they may be positioned wrong.
The arrow on the bulb should point UP at the motor for them to work right. let me say that again....
If they are pointing down...very bad.
If they are lying horizontal they might work until they don't sometimes and then maybe they'll work again for a while....
