- Oct 9, 2010
New member to the forum here with a couple of questions. I have a Chase 263 (1996 model) which I have repowered with the new Yamaha F200 I4s. I'm running the factory 19" props that came with the engine. I have about 15 hours on the engines. The question that I have is are there any other members that have a 1996 to 2000 model boats that have repowered with these particular engines? If so I'd like to know what props you're using and also how the engines are rigged on the boat, i.e., how high on the transom.
My reason for the inquiry is that I'm having a strange handling sensation at high speeds. I wouldn't quite describe it at porpoising but similar. I believe the engines need to be raised on the transom a hole or two and also that I need to go to a smaller pitch prop at least a 17" pitch.
I appreciate any suggestions.
