against the wind said:
thank u uno eric .. I understand exactly what ur saying , but a 200 yamaha carbed at wot 4800 rpms should be running more than 28 mph.. i am waiting to have the vessel surveyed but in the mean time im trying to get this problem resolved. im thinking low compression, what do u think :-|
Yes, it should be faster than 28 mph, but probably not by too much. At 4800 RPM, I'd expect my boat to be 32-33 mph.
I don't think it has anything do to with the engine though. Unless the drive train is slipping when it shouldn't be, the prop is going to be turning an RPM directly related to the engine RPM (differing by, I believe 1.86, which is the gear ratio for that motor). So if the motor is turning at 4800 RPM's, the prop will be spinning at 2580 RPM's, which will push the boat at whatever speed it can for the conditions, regardless of the compression of the motor. If the motor had bad compression, then it would have a harder time achieving higher RPM's for a given load. But since you can get close to what the rated WOT RPM is for that motor, I don't think that's a problem.
The only thing that can cause the hull to move slower than expected, since a 15x17 prop is pretty close to the expected correct prop for the rig, is excess drag, which would cause excess prop slippage in the water. Excess drag can be caused by a number of things...
1. Bad hydrodynamics (i.e. the bottom of the hull is not smooth)
2. Excess weight in the boat
3. Motor poorly trimmed
4. Prop hub is spun (so the propeller blades aren't spinning at the same rate as the prop shaft)
...to name a few.
Since we've got the same hull, same prop, and close to the same motor (which should have the same gear ratio), we can do some comparisons using this prop slip calculator:
http://www.go-fast.com/Prop_Slip_Calculator.htm
So, using the middle of my range of numbers, here are my prop slippage %
3600 RPM = 32%
4000 RPM = 31%
4200 RPM = 26%
4400 RPM = 20%
5300 RPM = 24%
My numbers are a little bit skewed because I can only run above 4200 RPM's in glassy conditions, whereas at 4200 RPM is typically where I like to be able to cruise in less than ideal conditions. So my prop slip calculations for 4400 and 5300 are on dead flat calm water, but the other RPM calculations are from less than glassy conditions. I also have trim tabs, which will affect the numbers slightly, too.
A lot of people say those slippage numbers are too high, but those people must only boat on flat glass lakes with very light boats. From my experience, which is mostly all fishing offshore in small boats, those numbers are typical for a number of different boats. Theoretical top speed for my boat at 5300 RPM WOT with 0% slippage is 46 mph.
With your numbers, you've thrown on 28 mph at 4800 RPM and 28 mph at 5000 RPM. Using both of those for calculation:
4800 RPM = 33%
5000 RPM = 35%
Those are, not unexpectedly, pretty high numbers, but not absolutely horrible. So there's something about that boat that's either causing excessive drag, or the prop hub is spun. Though usually with the latter, it won't be long until the boat won't be able to get on plane anymore with the spun prop.
Just my (probably more than) 2 cents!
