Finest Kind
In high winds or strong current, don't try to go straight into the slip and chance being pushed into your neighbors boat.
Instead, drive upwind/current close to your slip, put your boat in neutral and let the wind/current push you until you lay the side of your boat against the piling.
Then use your motor to pivot against the piling until you are straight, then just drive into the slip.
"your RubRail is your friend"
