Lil Lucky
I had my friend who's in the graphic arts industry come up with the design. If you want to do things right the first time, you should take note. DON'T CHEAP OUT! In many ways, this is the biggest way to stand out among other boats. I used my dad's first boat's name on my first boat. (Lil' Lucky). You can check my graphics on the GW Marlin gallery. I believe it's the latest pictures in that gallery. My friend uses a color booklet called a Pantone book. Basically, it can match any color vinyl including finishes like matte finish, gloss finish, metallic, semi metallic, gold or silver flakes, etc. I wanted to match the exact coloring of the GW colors. Let me tell you, it's spot on. I even got the gradient transition from dark blue to green as you would see on the striping around the hull on my logo. The font I used for the Logo is custom bought, but you don't have to go that crazy, but it does add to uniqueness. I HIGHLY RECOMMEND YOU DON'T CHEAP OUT ON THE TYPE OF VINYL. This is a must! I recommend 3M or Avery vinyl only. I'm using Avery A9 vinyl with additional layer of protection over the sticker. A9 stands for 9 year warrantied vinyl basically. They come in different levels of durability. Since most of you are in an environment around salt water, I wouldn't recommend anything less that 9 year. The colors don't fade and the actual quality of the vinyl won't peel. If you see peeling of vinyl, chances are they used the cheap stuff that you can make off a website for about $100. The typical vinyl used online is A3 which is for 3 years, but usually breaks up beforehand.
As for folklore with changing names on boats, there's a way around it. If you're taking the old name off from a previous owner, just save some that you peeled off and throw it under the deck. It'll always be with the boat then!
