- May 26, 2021
- Age
- 27
- Seafarer
Hello. So I recently Purchased a 1982 Grady White Seafarer 22'. for $500 bucks with a title and Trailer. I do believe it has Original Motor and Previous Owner was an older fella that kept the boat in Florida when he lived there came back to South Carolina in the past 10 years and the boat has sat for 3 years. but IT IS IN GOOD CONDITION. the previous owner said the reason he is he is selling it is cause someone came and stole a bunch of Wiring off the boat and the entire switch panel.
I am 24 Years old and Very Excited for this Journey!
Inboard Motor looks to be 5.7 V8. HERES WHERE THE QUESTIONS START:
down on the Harmonic Balancer I went to try and turn the Motor over and there isn't bolt heads. say on a truck down there there are bolt heads so you can turn and it will Turn the motor. how do I Turn this motor to Ensure it is Free ( before I hook a Battery and jump it LOL ). ALSO I PULLED TWO SPARK PLUGS AND THERE WASNT ANY RUST ON THE INSIDE OF THEM JUST ON THE OUTSIDE OF THE MOTOR. INSIDE WAS PRETTY CLEAN for sitting a few years.
the Oil Looks to have some water in it. today as I type this I just sucked the oil out ( with one of those hand Pumps you see on YouTube) and it had water in it. milky and just gross. I thought I got all of it. and I go to Fill it back up with the Quicksilver 4-Stroke Marine Engine Oil SAE 25W-40. and I went to check it it was milky again. what am I doing Wrong.
what carb came on these. I took the air filter off and this thing is SEASED TO THE MAX. almost nothing will move.
I am sure I will have more questions. PLEASE can someone shed some Light!?
