- Nov 3, 2019
- Age
- 52
New to me.....I have a 2001 Grady 268 Islander. Has the Jabsco manual marine sea water pump head system. It also has the option to pump out at sea. I am assuming there is a macerating system , looks to be attached to the top plate of the holding tank. Again I am only assuming by what I can see looking in the inspection port.
Above the head, behind the toilet about eye level there is a holding tank level indicator, as well as a discharge button.
I have not been able to power the display on the level indicator.
Does someone know if this power source is automatically turned on when the boat is powered on or is this usually on an accessory switch button or is there possibly a fuse that has blown inline to this head control?
My research from Jabsco says all waste lines should be replaced every 5 to 7 years also... has anyone had to replace their waste lines?
the boat is 18 years old but only has 230 hours so I cant imaging the head has that much use.
Thanks, Vin
Thanks, Vin
