Livewell Drain Plug Replacement
muznuts
Hi all,
I am the proud owner of a 2005 model 208 Adventure here in Sydney, Australia, had it for 5 years now and absolutely love it
The brand has only recently started being distributed here in Australia so information is not easy to get especially on small parts like this
Can any of you good folks here tell me if there are replacement livewell drain plugs available to buy, the boat never had them when i got it so i have made do with cork types till now but they leak
The drain is tapered white plastic like a countersunk screw (just over 1" down to just under 1") and has a double' key wa'y which makes me think there is, or was a special plug to suit
Any help appreciated, thanks
Murray
Reactions: muznuts
Hi,
There are (2) types of plugs and (1) live well tube.
The plugs that go in the bait prep station (if so equipped) and the fishboxes are rather small hard rubber that can be found at any hardware store nothing special.
The plug for the live well is a larger one (1 1/2") that is hollow and more pliable than the small hard rubber ones. It also has a loop top so you can pull it out easy. This screws into the bottom of the livewell.
The GW part number for the hard rubber fishbox drains is 11-124. Description is "rubber stopper".
The GW part number for the livewell drain plug is 11-242. Description is "drain plug".
The livewell tube is 11-245. Description is "Stand Pipe 9" Livewell Overflow".
Reactions: muznuts
Do you have access to a dealer by chance? If not, let me know and I'll check around and see if I can locate one to send you.
Reactions: muznuts
Halfhitch
Venice, Florida
The screw-in type stand pipe that dictates the overflow level can be left unscrewed a bit so water can also drain out those two "keyways" you spoke of. This help keep the build-up of contaminants harmful to live bait flushed out of the bottom of the tank and improves the longevity of the bait .
If your well has an overflow in the side of the well like mine does, you don't need the stand pipe, just the tapered plug or the soft vinyl plug with the finger loop.
Reactions: muznuts
muznuts
Wow, thats a very generous offer, thanks
I have emailed the dealer here with the part number you posted, they have only had the distributorship a year maybe (first in Australia) so getting small parts for existing owners might not be high on their priority list unfortunately...
I appreciate all the replies, thanks
muznuts
Thanks for that info, i dont require a stand-up pipe for the overflow, mine is set up with the overflow set into the side at the rear of the tank
So the plug im after restricts any water going out the bottom drain, the keyways are what restricts the cork or rubber ones from seating nicely for a good seal
Halfhitch
Venice, Florida
That's the same set up I have. I use the soft vinyl plug. It has a flange at the top that seals if pushed all the way down. If you pull it up a bit you can get some flow out the bottom to help clear the contaminants.
muznuts
Is it a Grady White part mentioned above or available elsewhere, thanks
Halfhitch
Venice, Florida
I can't say for sure. I am the second owner. The drain fitting in the bottom of the tank appears to be white nylon. From what I know of the original owner it is probably the one Grady installed. I can take a picture tomorrow.
wrxhoon
Sydney Australia
Hi Muz,
I'm in Sydney as well, I know the part you are looking for, I have one on my 228.
Have you tried Short Marine in Sydney?
By the way they are not the first GW dealer or the only one in AU. The other one that I know is on Gold Coast: Game and Leisure Boats, 247 Bayview St, Runaway Bay QLD 4216, ph: (07) 5577 5811 .
Give them a call they maybe able to help.
Reactions: Ozz043 and muznuts
I usually use my stand pipe in my livewell but I have the plug also. This should be what you're looking for.
Reactions: muznuts
Halfhitch
Venice, Florida
This is the configuration on mine. Both the drain and the overflow are installed in the same wall of the well. then they are teed together just outside the wall.
Reactions: muznuts
muznuts
Hi Muz,
Hi wrxhoon,
we have spoken online previously, on Sydney Angler, you offered for me to come and inspect your boat before i commited to buying mine, yours still going strong?
yeah i emailed Andrew Short, actually talked to them about it months ago with no joy, i actually thought the Gold Coast mob stopped GW thats why Andrew Short picked it up, might try them thanks
looks like i can get one pictured that will work well, is that what you have?
murray
muznuts
thanks for the photos, mines similar except the drain is in the floor of the tank
wrxhoon
Sydney Australia
Hi wrxhoon,
murray
That's the one KY put up. Like he said mine has both. On the Seafarers you normally use the stand pipe for livies because the outlet is there , you only use the plug if you want to have ice in there.
I remember now it is a while we communicated on SA . The 228 is still going great and the 250 optimax suits it very well. Yesterday I picked up my new boat from Port Kembla .
This time I bought a 2013 model 228 with hard top suits my fishing better , I will install wishbone outriggers , I have gunnel mount on the current sot top.
What type of fishing do you do? What's your call sign? Mine is SY321 and I normally go out wide well east of Browns depending where the fish are.
Reactions: muznuts
muznuts
New boat! That’s exciting, has it got a 4 stroke, I remember you preferred the direct injection 2 strokes
You Selling the old one?
Mines got a Yammy 200 HPDI, it’s been faultless with plenty of punch
Wishbone bases on the side of the cabin? Have you considered the through hard top grand slam type bases, had them on my last boat from the US, really good system
Yeah I usually fish out wide, don’t have an official call sign but my boat is named Game On, which is what I use if I get on 21, you won’t hear me on the radio much though, too many idiots
I’m planning on going out this week now that current has backed off a bit, not sure which day yet
