I think the engines are too low. They are mounted on a bracket and the water from under the hull rises sharply by that point. When it is bolted directly to the transom, the hull displaces the water so the engine needs to be lower so the prop stays in contact with the water. With the bracket, the water is coming up from underneath the boat, so the engine does not need to be so low.
