Sparkdog118
- Apr 8, 2020
- Age
- 54
- Ft Myers, fl
- Offshore
i use mostly quicksilver lubricants. the 2-4C grease is very good for the steering. quicksilver also makes the best lower unit oil. high performance gear lube is blue. I use it in almost all lower units. I would try rolling the cable out of the helm to inspect the cable worm gear and see if there is any metal on it from the gears. if you have a safe t helm< there is a pin to pull out. use the pin to push in the locking mechanism and turn the wheel at the same time. the cable will roll right out of the gear box.
