No worry at all. Maybe I didn't describe it as best as I should have and to be honest it's pretty hard to write and much easier to describe when looking at it in person.
Regarding the transducer flat:
The flat itself (looking from the outside/ bottom of hull) is parallel to the waterline. But from the inside, even tho it looks flat it's slightly angled. Maybe a quarter inch aft to bow.....at least this was the case with my boat.
Even tho the transducer flat is flat from the outside......and even tho it "looks flat on the inside bilge area" it isn't completely flat on the inside of the bilge area. The flat portion inside (bilge area) still has a slight angle Therefore an angled spacer was needed to be used for the inside to compensate for the angle.
My boat had an angled spacer with the original b744 and my marina had to make another one when it was replaced with the b765hl. To be clear it wasn't drastic but it was absolutely noticable. They even tried to install the replacement transducer without the angled spacer and you can see a slight gap on one side of the threads facing towards the bow.
Regarding the b765hl:
yes it's a direct replacement for the b744, and it upgrades you to chirp and also compatible with newer units. This does fit (dimension wise) on that transducer flat. Same dimensions as a b744. I couldn't find a better option that would fit on that transducer flat. I was hoping I could find something that would be 1k, have similar dimensions and compatible with my axiom pro, but at the time I couldn't. If I recall even tho the outside/bottom hull side of the flat was approx 8 inches.... A transducer larger than the b765hl wouldn't sit flush with the bottom of that transducer flat as It's slightly tapered towards the bow end of the flat and caused an issue.
Regarding 0 degree, yes definitely use a 0 degree on that transducer flat.
