Sardinia306Canyon
- Oct 11, 2023
- Age
- 60
- Island of Sardinia
- Canyon 306
FA,
did you installed the DF200's or a dealer and can you remember if the you/they used the same hole as the Yamahas before.
If so, you should lower the engines one hole, on all boats i changed from Yamaha to Suzuki i had to lower one hole otherwise propeller ventilated too early. Lowering one hole does not affect performance or general behaviour negatively, but will avoid problems with ventilation.
You can hear ventilation when the sound of the engine changes, same as when you trim up too much, in both cases the propeller/s start to pierce the surface and suck air and that generate this particular sound.
When props start to ventilate rpm will get up but you loose traction and boat become slower.
Chris
Chris
