Paul_A
- Feb 25, 2019
- Adventure
My boat had that same pushbutton breaker as the one next to your battery switch.
Be sure to check it, I ended up replacing mine. Was sticky.
Regarding your fuel tanks I can only tell you what I saw when I removed the then 25 year old tank out of my boat. The top had obvious pitting and a couple of pits were deep enough that the tip of a screwdriver went through easily.
But the sides and bottom were the real problem. Grady laid rubber strips between the tank and the false floor and had rubber strips on the sides and top where the raw wood was screwed into the stringers to create straps of sorts.
Take that board off the top of the rear tank. That's where you can get a quick look at what might be hiding underneath. If it were mine if I saw any deep pits on top I would pull and inspect the sides and bottoms. Last thing I ever want is my automatic bilge pump pumping raw gas when I'm 30 miles offshore.
