- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
Good catch - it certainly does look like the red and green are mounted on the wrong sides... and of course facing the wrong way. But I don't see anything that is blocking (once they're flipped side for side) their visibility? The stanchions directly forward of them don't impede anything since the visibility should only be directly straight ahead to 112* aft. In other words, BOTH red and green should only be visible by another boat is both boats are exactly head-on - otherwise, only one light should be visible. But still a great eye for seeing that!Your nav lights are backwards. And if you did it on purpose, the stanchions are blocking the intended "cross visibility". Illegal setup.
(I assume we're talking about the pic from post #17?)
WOW! I sure didn't catch that till it was pointed out. Man, that ocnsir has a sharp eye. I wouldn't want to try to sneak a beer out of his cooler.![]()
If you read his post, he can save $200/month by doing this. Plus, there's no real "hacking" going on - it can all be reversed. But, for him, as he mentioned, it's worth it - and in the end, that's all that really matters. Hence the saying "to each his own".Most marinas charge for the registered length of the vessel or the slip size itself, not the true stem-to-stern measurement. My 232G with the bracket is easily 27' long, but I paid for a 23' boat when it was rack stored, and just the slip rate for the dock I want to be on at the present marina. I can't believe you'd be willing to hack your boat up because of the pulpit.
