OX66 charging second battery
As has always been the recommendation for parallel battery banks, it is important that the same type, model and age batteries be paired together.
Not only is the voltage of the batteries important but more so is the internal resistance/impedance of the batteries. That parameter can differ for different battery technologies.
I am not certain but the article may have been referring to paralleling different voltage batteries like a 12v and a 6 volt together as opposed to a 12v at 12.5 volts and another 12 v at 11.2 volts
I have forever cemented myself in Grady White forum lore as the person who questioned 40 or more years of common practice. Sigh, You all are too kind not to beat me up for reposting a Reddit question. But at risk of getting another dunce cap for today could someone please explain what Skunkboat means when he says switching between 1 and 2 is stupid? Does that mean he moves his battery selector from off to 1 (starter) but never to 2 (house) or both, because the aux charge cable is taking care of the charge on the house? Or does he move from off to both and never to 1 or 2?
If you have a severely discharged or damaged battery and you parallel it with a good charged one, it will "try to charge" the bad battery. In extremes, it can move a lot of current and not be pretty.
It will definitely discharge the good battery, possibly leaving you screwed.
For that reason, BOTH position is supposed to be a last resort.
I know many people use it as a "charging" position. Many people doing the wrong thing doesn't make it right. Some dealers even tell people to do that.
Using BOTH defeats the point of having two batteries and a switch. Many people forget to take it off BOTH.
You have a one motor, one battery switch, 2 battery setup. Lets call them 1 & 2.
Neither is technically the "primary" battery. Whichever position the switch is on connects that battery to start and charge ...AND the House 12V to the dash.
The point of that setup is to always have one battery that is fully charged in reserve, in case the one you are using won't start your motor.
If 1 doesn't start, switch to 2 (not BOTH). If neither will start you are already screwed so try BOTH.
Often the auto-bilge pump, and possibly stereo memory, is directly connected to the "1" battery. A second autobilge may be on the "2" battery.
Ideally, you would use the batteries equally. Switching the one that you use each trip. That is a pain. Nobody remembers. Its stupid.
Use the Aux charging cable...
I think I may be starting to understand what I had backwards in my head, thanks to your reply, and it has implications for what types of batteries go where. Please tell me if I have this straight. If I move from Off to position 1 when I use the boat, then battery 1 should not be a starting battery, it should be a dual purpose battery, because it is going to start the engine AND run the house. The backup battery number 2 will never be drawn from normally, it is there like a shadow, and is always kept topped off because it has an aux charge line on it. Number 2 battery can be a dual purpose battery as well, but in most cases is probably just a starting battery because its ONLY purpose is to start the boat if #1 is unable to. Do I have it right?
...when he says switching between 1 and 2 is stupid? Does that mean he moves his battery selector from off to 1 (starter) but never to 2 (house) or both, because the aux charge cable is taking care of the charge on the house? Or does he move from off to both and never to 1 or 2?
in a typical setup from grady, one motor, one switch, two batteries, "2" is not "the House". The house is connected to the FEED (or COM) of the switch along with the "starter" cable of the motor.
The house battery is whichever one the switch is on. The same one that starts the motor and gets charge from the motor.
You can separate the House from Start. IMO, it makes more sense than the OEM setup. If you do, you need to charge the house somehow. Either an AUx cable or an ACR.
I will preface this by saying that I ran a 20 footer for 18 years with a single Group 27 dual purpose and no battery switch. Every 5 years I replaced the battery.
As long as there was nothing left "on" on my dash, I didn't need a battery switch. I had a VHF, gps/ff and lights. No stereo.
I now have a 26ft and twins which is different than your case, so I won't talk about that.
You COULD separate the 12V house(which we will label (2) from the Start (1).
In that case you can have a deep cycle House battery (you can still use a Dual Purpose thats same as your start battery)
Move the House feed from the FEED(COM) post of the switch to directly to the "House(2)" battery pos terminal. Doing this disconnects House 12V from the MOTOR.
Connect Aux charge cable to House(2) battery pos terminal so that it will charge from the motor
Bat 1 is connected to switch position 1. In normal operation, you put switch on 1. Bat 1 starts the motor and charges thru the starter cable.
Bat 2 is connected to switch position 2. You can use switch position 2 in an emergency if your bat1 will not start the motor.
Bat 2 is always connected to the House. (you should put in a switchable breaker to turn off House). bat 2 charges from the Aux cable whenever the motor is running, regardless of switch position.
I would connect autobilge to Bat2
You could replace your 1/both/2/off switch with a blue seas dual circuit plus switch which will turn ON/OFF the start and house and allow emergency start using a "combine" feature which is like a "both"
Blue Seas has a "add a battery" kit that does all of this using a switch and an ACR https://www.bluesea.com/products/7649/Mini_Add-A-Battery_Kit_-_65A
What you gain from separing the House is that your House loads will not be draining your START battery, ever. Your start battery starts your motor and raises and lowers your motor and charges while its running.
You turn the switch to 1 and go boating. You turn the switch off when you are leaving the boat. You never use 2 or Both unless there is a problem
Your Bat2 charges regardless of switch position.
Your Bat1 will not be cycled low over and over again from running a stereo at the sand bar all afternoon.
quick drawings...
What you have
to separate house and add Aux charging
No worries, Chinookie! Everyone starts somewhere with their "knowledge base"!
As you're starting to figure out, it's a little confusing because there are multiple theories on the best way to use two batteries. And it really boils down to how they are set up for charging (one or two charging leads and where they connect, ACR, etc) and what makes the most sense for YOU.
OK guys. Here's my update on what I've done.
Rcvd the cable last Fri. ( nothing but a wire with a 50 amp inline fuse.)
Really straight forward install, took about an hour and was no problem at all.
(Rigging tube was no problem)
Haven't started the motor to check anything yet.
Mine is wired just like SkunkBoat's first drawing except my bilge pump goes to bat1, therefore bat 2 is never used for anything except as a backup for everything.
Next can of worms.......
Switch position in bat1- both bats charging like I wanted...
switch position in bat2-both charge leads applied to bat2 and no charge on bat 1.
So I guess the aux charging output is to charge a third isolated battery with on/off switch for house use and have bat 1&2 charging as selected on the battery selector switch for starting only. (3 battery setup.)??
Appreciate all the input, a lot to think about.
quick drawings...
What you have
Skunkboat thank you so much for your helpful replies! I am very grateful, and I know others will benefit too. What a great forum.
Doesn’t sound right, unfortunately I don’t have time to look at it right now
Oh. I understand. You didn’t separate the house as bat 2. You are Correct that in position 2 the bat1 is not connected to the motor and so it doesn’t charge. The point of the aux cable is to charge bat2 at all times. So you don’t need to switch to 2 to charge it. You would run on 1 and 2 would be your “emergency start”. When on position 2, the bat 1 is disconnected
It sounds like you may have installed the 2nd charging lead from the motor incorrectly. The charging leads should either go directly to the batteries or be piggybacked on the posts on the back side of the battery switch to the #1 and #2 posts. If you can, it's preferable to go direct to the batteries - but that's only slightly better than to the switch.
Reactions: Sardinia306Canyon
so, it’s not that it’s for a third battery. It’s that it’s actually better when you’re using the second battery as the house. The point of the aux charging is to charge the house battery all the time and to use the start battery only for starting and raising and lowering your motor. You would only normally ever be running on switch position one. You start battery will last longer, and not risk being run down by something on the house.
Most of the setups using an ACR are the same way
The point is to get away from switching between batteries to start and charge
I had twin ox66. Ran both aux chargining leads to a House bank. Worked perfectly for years.
I have Zukes now. Same thing.
Yep,
had the same from my first Yamaha 150 carbed to the newest 2020 F300 and all the Suzuki's i had, either single or twin outboards.
Chris
LOL I am that nobody, since my 208 is set up that way. On every trip outbound using one battery and return on the other. If I forget to switch on the way home I will run the boat in the slip to give the second battery a bit of a charge. I have a logbook at the end of each trip and that includes which battery I ended the trip. But I guess I am a bit obsessive and don’t want to get stuck off the coast of NJ with no power. The batteries are 2021 so keeping track of them as they get older. This year I will get them load tested for peace of mind.
