- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I did it before.
My dealer said if you don't want to wait, take em off bring em in and I'll give you the new ones to try...
It shouldn't cost you anything to test props and get the right ones. Thats my experience.
I can't imagine a dealer just saying one size fits all..there you go...
If he absolutely won't test props I would tell him to refund your prop money and get Powertech props
Higher pitch will lower your max rpm but increase your cruise speed and top speed and probably your mpg @ cruise.
...to a point... at some point the higher the pitch will cause you to bog down on takeoff. Its a trade off.
When you gun it the motors should load just slightly. I'm guessing yours spin up like mine did when you push the throttles
test them with a full load of fuel. test them for a day out the inlet in some seas. A 10 minute test run with a 1/4 tank in flat calm in the river means nothing.
Test them with motors all the way down on take off...then raise them as soon as you are up.
Test from a dead stop with them up at cruising trim. they probably spin and maybe won't get you up. Not unusual
Do they raise all the way out of the water? If not I can tell you about that too..
