Pulled the lower unit, the shifter is lined up fine. But still I am not pushing water up to the top of the engine. I looked to see if the water tube was lined up OK with the water pump housing, and it looked fine. But still no water.
So the question is: are the impeller arms going in the right direction? If you look down on the L U from above, and turn the driveshaft clockwise, the arms are flexed backwards. They lag the center of the impeller. Suggestions?
Are there new rubber grommets for the water tube to go into?
