- Oct 16, 2007
- Age
- 72
- Cape May, NJ
- Islander
I used Coosa board 1/2”. 4’ x 8’ sheet was almost $200. It’s overkill but my time is worth something to me. It’s a forever fix.
Plywood is ok too but you really should vacuum bag the part. This will draw the air out and replace it with epoxy. It also petrifies the plywood. GW didn’t do this and water that gets in go to the inside plywood layers. They suck the water up, break down the glue and delaminate. Freezing probably doesn’t help either.
