I finally got tired of my original F250 making oil so I went ahead and turned it into a brand new 2019 BF250. Now I hope I can finally troll without changing the oil every 20 hr.
It's going to take a while to get used to that big silver thing back there.
I also added a Bob's Machine Shop manual jack plate to set the engine back 5.5 inches so that the lower unit will no longer interfere with my side scan transducer. They do a really good job and even machined out a piece so that the mounted jack plate won't crush against the transom bang plate (which I also replaced with the new vinyl material).
I haven't had it offshore yet but I put on 3.5 hr of break-in runs in the river and bay. The engine and jack plate added an additional 100+ lb to the transom load which dramatically changed the handling characteristics of the boat. It no longer bow steers at low speed and for some reason or other, it no longer lists to port when on plane. I used to need 30% port tab to keep it level. The extra weight buries the scuppers but water doesn't flow into the cockpit with 2 not too fat guys in the stern. However, I image that boots will be needed with a few of my fluffier friends are aboard.
It will be interesting to see how the boat handles head seas when I set up the anchor offshore. With the F250 it would veer from side to side making it very difficult to position the boat where I want.
Do any of you folks with 228s have problems with bow steer when off plane? I've been in a few of them but I can't recall if they had the same issue as the 226. SV2 hulls are very quirky. I have a love/hate relationship with mine.
