Jody said:
I'm going to change it out, like it was said in a bad situation using two hands on the mic is not a good idea. Plus I usually have a few friends on the water and in the beginning of the day we spread out to find the fish. Last Striper season I would just use my cell phone but offshore that won't be a option and pushing the two buttons at once will piss me off every time I do it. One thing I will look at is to see if I can jump the button in the mic and lock it on hi.
Locking the button probably wont work since it is a toggle function usually. If so that button could end up switching a HI channel to a Low.
There is another factor that I didn't mention.; That is reception. In some instances, you may be heard but may not be able to hear. The same for not being heard but hearing others.
Reception is dependent not only on the senders power level but your sensitivity and perhaps noise rejection.
So if you have found that others hear you but you don't hear them, increasing your transmit strength isn't going to help.
Poor reception and/or transmission strength could be an antenna issue, either the antenna itself, the cable and connector or a combo. Your radio could be bad too and just not transmitting at rated power.
Lots of radios , especially older models can be permanently damaged if the transmit button is activated without a proper load (antenna) connected)
I agree that you would benefit by getting a new more up to date radio but at the same time, I wouldn't want you install one and still have problems.
