Remote engine flush
Caburke1
St. Petersburg, FL
I keep my boat on a lift and I know this is going to sound like I'm really lazy, but, the remote engine flush is my favorite feature on my new boat.
mleads310
Brooklyn NY
Didn’t like how I did it the first time, changed fittings.
Looks very good. Was debating on doing the same thing. Do you have any pictures of the material you used and or the connections leading all the way back to the outboards?
Mr.crab
California
Just 5/8 Braided hose with plastic chase through stern , left the hose fittings on motor so I can attach back to motor in chase of a problem .
Joefitz
This is what I set up on my Grady to flush engines
Mr.crab
California
I don’t see caps on your hose fittings, will water come out when motors are running?
Joefitz
They are quick disconnects one hose is not on them they are sealed off
TMC PARTS
Milford, DE
www.taylormarinecenter.com
just a though for some of you guys, i can order the current factory quick connect flush set up used on the current grady white models. very nice looking set up.
Clark.N
Norfolk, VA
What does the kit consist of for a single engine 232 Gulfstream (hose,fittings,length of hose?
TMC PARTS
Milford, DE
below is the parts list from grady white for the optional single engine flush kit on your boat. if you want to order, give us a call
28-289 ENGINE FLUSH SINGLE 232
11-381 Hose 3/8” White Tracer (Cold H20) - however many feet you would like depending on mounting location
11-548 Coupling 3/8” Hose Barbed Panel Mount
11-549 Coupling Insert/Valved 3/4” GHT (Male)
22-449 Panel Engine Flush Single
Reactions: Ridge Runner
panabal
Freedom 307
Can you provide pricing for the above? Thank you!
