blindmullet
Tanks looked like crap from the plywood glue leaking on them but they cleaned up well. No salt water corrosion on tank top. Obviously I can't see the sides well but paint was still adhered to the tank.
Deck hatch project finished. Coosa board, West System epoxy, glass fabric covered and vacuum bagged. Holes re-drilled and epoxy coated.
Pumped water out from underneath tanks - no fuel. Hooked up smoke machine - no leaks. Pressure tested tanks and sprayed hoses - no leaks.
Changed access ports out. Caulked everything with 3M 4000 including the deck.
It's overkill but done right done once!
Photo after vacuum bagging before glassing in.
Run some thick filets on that support. Those sharp angles will be hard to glass.
