Yes, that wood is dried out and cracked. If the crack is across the top side which it looks like, that doesn't affect the strength that much since the load is in compression and the crack doesn't diminish the load capacity.You could use some epoxy adhesive and deck screws to tighten up the crack . I wonder if the underside mounting bolts helped cause that crack.
If you change lumber, I would probably change all bunks and recover with new material.
I reread your original posts and see that you don't trailer a lot. You use the trailer for maintenance. If the bunks are solid ( pieces can't be easily peeled or broken off, I might e tempted to reuse the old wood with some repairs and new covering Sorry but I can't judge the condition of the bunks from photos
