- Jul 23, 2019
- Age
- 77
- Explorer
8/4/24 Both Fresh water pumps continuously run whether the switch at the helm is "on or off". They will not turn off unless I pull the "auto type fuse" on the fuse block in the cabin. No water comes out of the faucet in the cabin lavatory or the gunwall shower or hand faucet.I'm confused. What is it you are trying to fix?
The pump that is running that shuts off when you pull the fuse is not on a switch (well battery switch). It will turn off when the pump primes and pressurizes the shower water line. If you got water in the shower handle and it still doesn't shut off then the switch inside the pump is bad.
