Teak Refinishing
I'm super pleased with the refinishing of my teak. This was a quick project. 20 min to remove trim, 2 hours sanding, and maybe an hour total time applying teak oil (3 coats). The teak oil took a few hours to dry between coats. I couldn't be happier with the results and look forward to getting these pieces back on the boat when the weather warms.
Nice transformation!! That will look great when you put it back on the boat.
FLWhaler
Where on the seafarer do you have Teak?
The boat is a 1989 and she has teak trim around the helm and cockpit. The door to the cuddy is teak as well as cuddy trim pieces. The photos show the trim at the base of the gunnel-bolster area and the rails near the deck of gunnel-mounted fishing rod holders. I saw a photo someone had posted of another seafarer and I noticed GW had moved to plastic trim in later models. I'm not sure when that transition happened, but I'm glad to have the teak, although it will require attention.
I've got a few pieces of trim by the helm that got saturated with hydraulic fluid from previous owner failing to correct leaky unit. I can't imagine the teak oil will take on these pieces. I don't have any teak on hand, but I've got some walnut that I'm going to cut for replacements. I think it will look nice and hold up. Does anyone have experience with walnut in marine environment?
Super nice. Hope it holds up for you.
