40 is too fast for a 22 foot boat in anything but glass smooth water. Spend some time learning how the boat reacts with both trim tab and engine trim manipulation.
For the trim tabs you’ll want to use them in short bursts of maybe half a second (as others have said). Remember to retract them when loading the boat on the trailer at the end of the day.
For engine trim try having your engine gauges display trim percentage so you can get some baseline numbers to work with; eventually you’ll get a feel for it and won’t need to look at the gauges.
From the sound of it you might have your engine trimmed too far down right now if you’re pounding the same at 20 and 40. Trim trimming up a touch and you shouldn’t be pounding so hard at 20.
Without knowing the exact specifics I’d guess you should be able to cruise comfortably around 25 knots; a 4 blade prop will help a lot too.
