- Sep 15, 2013
- San Diego, California
- Adventure
I'm not familiar with the 226, but can you access under the pedalstal seats, where the tackle locker is?
No tackle locker on the 87 226, only fish box and insulated cooler / live well. There are small screw in access openings above the locations for visual inspection, but not enough room through them to actually remove the hose clamps, hoses, and fittings. My forearm doesn't even fit through the hole, a boat mechanic looked at it yesterday and said I have to cut a new 5" hole through the inside of the boxes then install covers over the holes afterwards. The forward floor drains will require the small access panels to be removed and the holes cut bigger, then 5" access covers installed. I love the boat for how it's built and all it can do with great versatility, but these very important drains should of been designed so to have adequate access for replacement since failures of these fitting could be enough to sink the boat. I'm sure I will forget about this experience once it's done and I can enjoy the boat again, but right now I'm really aggravated having to cut four new 5" holes in the ole girl. It's still up in the air if these holes will allow me to adequately reach the hose connection underneath at the deck drains. It will allow access to the through hull part, but it will be seen if I'm able to manipulate at all the underneath connections. I'm hoping I will be able to get a small 5/16" socket on the hose clamps to remove them, then use a razor knife to slice the hose allowing it to slide off. The hoses are so dried up that they will not slide off the nipple, and the deck/ fish box fittings will just snap off trying to do so. Doing all the replacement by feel with having only one arm in the access hole is certainly a challenge, and I will need to have a string attached to any tool so that it can be retrieved if dropped. I'm going to spend a few days thinking everything out before attempting this, just worried about butchering anything up trying it. One problem is the very cramped area at the helm floor drain, it will limit my body position while having my arm in the access hole. One thing is for sure, if I can pull this this off, it will be a huge accomplishment and worth a big beer chug.
Yeah...I had to make some access holes and then close them back in when I was done. I tried to do it without cutting but....wasn't happening.On my '04 after removing tanks, you have no access to the sides.
View attachment 9703View attachment 9704
My brother had the skinny arm and was able to put his whole arm through the access hole. This very difficult job is now finished. What a PITA!Here is one idea to consider. The hose barb on a thru hull is smaller diameter than the threaded part. If the TH is located where you have a hard time reaching, forcing that hose on will be difficult. But, if the hose will fit thru the opening in the hull, put it on the TH first, and feed the whole thing thru from the out side. A quality, thinner walled hose may be available some where like Ag Supply. Then you only have to deal with the nut, and the clamp, on the inside. Some hose barbs are significantly smaller than the threads, so if this is not a life-or-death drain, like a livewell, using a smaller hose may be a solution to one or more TH's.
Tighten the TH nut from the outside, if necessary, before attaching the other end of the hose.(I posted the socket tool I made for this earlier in the thread. I have discovered that there is a tool for this, called a step wrench. )
https://www.deepblueyachtsupply.com/3bthw50150-thru-hull-step-wrenches
Start with the most difficult connection on either end of each hose.
It was actually boat life caulk which I referred to as 5200, thought it was the same stuff different company. All I know is they are sealed and ready for another 30+ years.Reading through this thread... glad you got it done, Steve. Yeah, some things around a boat can be quite challenging, to say the least. But, hey, I guess it's the nature of the beast!
But one note... Grady didn't use 5200. If they did, you would have destroyed the gelcoat/fiberglass trying to get it off. I hope you didn't use 5200 for the new ones? 5200 actually has VERY limited places where it should be used. It's essentially superglue. It should be looked at as a permanent adhesive, not a sealant.
It was actually boat life caulk which I referred to as 5200, thought it was the same stuff different company. All I know is they are sealed and ready for another 30+ years.[/QUO
That is a huge accomplishment, congrats!!
That's a HUGH accomplishment, congrats Sir!!It was actually boat life caulk which I referred to as 5200, thought it was the same stuff different company. All I know is they are sealed and ready for another 30+ years.
Here are some pictures, they show just how cramped and small the access holes are and how nice the new thru hull fittings turned out. I hope to never have to do that job again, proper access would of made it a very straight forward job. I guess I can't complain too much though, since some brand name boats require you to cut the floor out to service the fuel tanks.I agree heck of a job. Glad you could change those hoses without cutting the deck. Nice job. Attach pics when you can.
