rorkin
journeyman said:Think about the problem like a lever.. That is what it is..
A boat is not a simple lever. It has mass! When you change the height of the tongue on the trailer, the weight distributed over its axis changes. Think about a half-filled fuel tank! Mine sits just about over the axles. A hundred gallons could be either weighing down the bow or stern. Fill her up and everything changes! Hundreds of pounds shifting from front to rear depending on the height of the mount. And it will also shift in transit. So getting the right height from the start is rule one!
Everyone's rig is different and all problems are not solved by one simple answer. That's why we love this site and all who participate :wink:
It is still a lever.. When the tank is filled it changes the weight either in front of the fulcrum point or behind.. depending where the tank is on the boat.This will then increase the tongue weight if in front of the fulcrum and decrease if in back. If the tank is precisely located over the fulcrum point, then I guess if it is half filled and and then all sloshes to the back if the trailer is tilted then it can affect the tongue weight. I don't think you will find that to be the case. In either event tongue weight should be determined with normal towing load.. Gear and fuel
The normal towing weight is the total of loaded boat and trailer
The tongue weight will change with load positioning
I don't want to appear stubborn .
but the ball height does not affect tongue weight.. It only affects stability and driveability if there is too much deviation from level.
Suppose you started with a level trailer at a given ball height.
You then found that the tongue weight was only 2 % of total.
So you then move the boat forward on the trailer to achieve the proper tongue weight (as acurately measured on a scale).
But if the increased tongue weight caused the rear of the truck to drop
3 inches .. Would you run it that way ??. I hope not. That is why ball height can't be rule one.
Perhaps this is a chicken and egg problem. The tongue weight should be a given percentage of GVW (trailer and loaded boat).. and the
trailer should be level. Levelness of the trailer is a function of ball height and your truck's suspension when the trailer is hooked up.
I would set the constant (tongue weight) which is determined by position of the boat on the trailer first. Again.. ask a trailer manufacturer.
When they design an adjustable trailer, they cant worry about the receiver height of every tow vehicle. The trailer is designed to be towed level with the proper tongue weight for the given load. I rest my case
