Had a pretty good restoartion day. Replaced the fish box drain thru hulls and livewell overflow. Had to seal up the hole from the sink drain..note to self..before cutting off old thru hull from the outside, check out where it is on the inside....I could not even come close to reaching the thru hull from the access hatch way up high.....I also removed the rear access hatch and exposed the filters, etc. Ugly in there..douched the hole with bleach and grease lightening and cut out most of the wooden shelf where the old oil tanks used to sit. With access to the bilge, sucked up about 1/2" of dirt and crap with the shop vac....ran into west marine and grabbed a new 3/4" thru hull while picking up dinner...after dinner, drilled a hole in the bottom for the new thru hull and insatlled the unit with screws/bolts and 5200. I can abandon the thru hull under the spalsh well, which I could not access well. I will seal that hartch and access hatch real good now. The new thru hull transducer will go in tomorow morning and then I can prep the bottom for paint....next weekend I will go after the fuel lines and uncover the fuel tanks.....,..wish me luck......
